Hempel
Mar 15, 2024Follower
I could not access 192.16.1.1 or routerlogin.net from Edge or Chrome
I had the same issue. I could not access 192.16.1.1 or routerlogin.net from Edge or Chrome. I downloaded Firefox, and that was able to connect.
schumaku
Mar 16, 2024Guru - Experienced User
Try the more appropriate 192.168.1.1 LAN IP address instead.
Tell us more about the unspecified WiFi Router (we assume Netgear), and what model, .... FMI https://kb.netgear.com/10727/How-can-I-find-my-NETGEAR-device-s-model-number
Either way, routerlogin.net /.com can only work if connected to that very same LAN or Wireless anyway, not having configured and with an active a VPN on the computer.
