milqueto
Apr 28, 2016Aspirant
I deleted the default Available Network Folders
If this has been covered, I can't find it, so apologies. But, I have deleted my default Available Network Folders, and I don't know how to restore it. I have hit the master reset, but it's still gone...
- May 02, 2016
Well, I thought I did.
I did another hard reset. Redid all my settings, which I had saved, re-inserted the USB, and it's now on the network. I don't know what it was. But all is right with the network now. Thank you for all the help.
milqueto
Apr 30, 2016Aspirant
Yes, the configuraton file. Here is what I have:
It should look like this (captured from the online manual):
How can I restore the default one?
VE6CGX
Apr 30, 2016Master
How did you save config. file. Manually by yourself or...?
- ElaineMMay 02, 2016NETGEAR Employee Retired
milqueto Is the USB still connected to the router? Have you tried unplugging and re-plugging the USB drive?
How about using a different USB drive, will it still not show anything under Available Network Folders?
- milquetoMay 02, 2016Aspirant
ElaineM I have tried different USB devices, and none of them can be detected on the network. It cannot be detected by the desktop nor the laptop. After I deleted that file shown above, I can't get any device to see the USB.
- VE6CGXMay 02, 2016Master
Did you configure the Readyshare of the router after connecting the formated USB device?
