milqueto's avatar
milqueto
I deleted the default Available Network Folders
If this has been covered, I can't find it, so apologies. But, I have deleted my default Available Network Folders, and I don't know how to restore it. I have hit the master reset, but it's still gone...
  • milqueto's avatar
    milqueto
    May 02, 2016
    Well, I thought I did.
    I did another hard reset. Redid all my settings, which I had saved, re-inserted the USB, and it's now on the network. I don't know what it was. But all is right with the network now. Thank you for all the help.
