DS5's avatar
DS5
I forgot how to turn off WiFi
My Netgear router uses the Netgrear genie software. It is tied to Firmware version V2.02.23.   I used to run it with the WiFi off, as I prefer a wired connection. The two WiFi lights were off since...
  • DS5's avatar
    Aug 30, 2023
    In the light of day, I closely examined the Advanced menu items in Genie. I discovered "Enable wireless gateway radio." Unclicking those two boxes shut off the WiFi. Job done!
    BTW, mine is a C3700 router, which the Associated Products field prevented me from entering., perhaps because it isn't being supported now. Not cool...
