CathiE1
Jul 17, 2022Follower
I have a N750?WNDR4000 how do I update any updates?
Jul 17, 2022Guru - Experienced User
What firmware version are you on?
You can manually update it.
You can get the firmware and the manual goes over how to install it.
https://www.netgear.com/support/product/WNDR4000.aspx
