Rons11FollowerNov 16, 2020I have a Netgear nighthawk AC1900 How do I switch from 5G to 2.4G? My new security camer will not work with 5G
plemansGuru - Experienced UserNov 17, 2020If you're using smart connect, disable it. Then you can choose which band to connect to
