jesusyogie
Jan 20, 2016Aspirant
I have a netgear Wndr3700 and everything is fine except 4 laptop.How can I bridge netgear R6300V2?
- Jan 23, 2016
Hi @jesusyogie,
1. Are you looking to setup a separate network using the R6300v2 or set it up as an access point within the same network?
2. Setting it up as a bridge will require a different set of steps as well. You may refer to the link below for the user manual and the steps are found on page 102.
http://www.downloads.netgear.com/files/GDC/R6300V2/R6300v2_UM_20May2015.pdf
3. The credentials that it is asking for are for the router admin page. By default the username is 'admin' and the password is 'password'.
Dexter
Community Team
Retired_Member
Jan 21, 2016Which part of the manual are you having trouble with?
jesusyogie
Jan 21, 2016Aspirant
What website do I go to in order to hook up the R6300V2 router as abridge router to the WNDR3700 router?
- jesusyogieJan 21, 2016Aspirant
I used www.routerlogin.net and that website was looking for a network name and password. Do I input the new network and password that came with the R6300V2?
Sorry for the spread out answers. Prior to the earlier inquiries I made I plugged the R6300V2 into power. I then connected a cat5 cable from one of the 4 internet slots on the WNDR3700 netgear primary router into the "yellow" internet slot of the R6300V2 router. I then went to the www.router.login.net website and was asked to input the router name and password. Do I enter the R6300V2 router name and password? I entered the primary router (WNDR3700) 5 gig network name and password and was rejected.
- DexterJBJan 23, 2016NETGEAR Moderator
Hi @jesusyogie,
Dexter
Community Team
