jesusyogie
Jan 20, 2016Aspirant
I have a netgear Wndr3700 and everything is fine except 4 laptop.How can I bridge netgear R6300V2?
- Jan 23, 2016
Hi @jesusyogie,
1. Are you looking to setup a separate network using the R6300v2 or set it up as an access point within the same network?
2. Setting it up as a bridge will require a different set of steps as well. You may refer to the link below for the user manual and the steps are found on page 102.
http://www.downloads.netgear.com/files/GDC/R6300V2/R6300v2_UM_20May2015.pdf
3. The credentials that it is asking for are for the router admin page. By default the username is 'admin' and the password is 'password'.
Dexter
Community Team
jesusyogie
Jan 21, 2016Aspirant
What website do I go to in order to hook up the R6300V2 router as abridge router to the WNDR3700 router?
jesusyogie
I used www.routerlogin.net and that website was looking for a network name and password. Do I input the new network and password that came with the R6300V2?
