WooBear22
Sep 23, 2022Aspirant
I have an AC2350 Router and wish to attach USB portable Hard Drives to Router to play on Roku Media
I have an AC2350 Router and wish to attach USB portable Hard Drives to Router to play on Roku Media. Not sure how to set that up. I am not computer savvy at all so step by step instructions would b...
michaelkenward
Sep 23, 2022Guru - Experienced User
WooBear22 wrote:
I have an AC2350 Router ....
Which one? AC2350 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
One of the R7500s?
WooBear22
R7500v2
- WooBear22Oct 06, 2022Aspirant
Not Working. Plugg in usb drive and according to Netgear router login it does not know a usb device is plugged in. White light is on usb device.
- michaelkenwardOct 06, 2022Guru - Experienced User
Is that the browser graphical user interface (GUI)?
What is this USB drive? Did you find this?
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Not complete or up to date, but it is a useful guide.
Did you read the section in the manual Share Storage Devices Attached to the Router ?
Yes (GUI)
A 2TB drive and a 4TB drive using NTFS
