Mph3842
May 27, 2021Aspirant
I have an R6400 and want to connect a HDD via USB as a NAS drive
I have a Nighthawk R6400 router and have a HDD connected to it via its USB port. I want to set up Readycloud but cannot seem to do it. Advice please?
RVALENZ
May 31, 2021NETGEAR Employee Retired
Hello, Mph3842,
What seems to be the error when setting it up?
https://www.netgear.com/support/product/r6400.aspx#docs
Check the link out there should be a manual for the readycloud setup.
Rhys
Community Team
Mph3842
Jun 01, 2021Aspirant
Thanks for your reply. When I look at the Netgear Router page, under Readyshare, the Readycloud button does not appear (see photo). The USB drive I have connected is an 8TB Seagate Hub Plus.
- michaelkenwardJun 01, 2021Guru - Experienced User
Readyshare is very picky about the USB drives it will accept. 8TB is too big for most devices. The limit seems to be about 4TB.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Your subject says "want to connect a HDD via USB as a NAS drive". By convention NAS usually means Ethernet. That's not USB.
- antinodeJun 01, 2021Guru
> I have a Nighthawk R6400 router [...]
R6400[v1] or R6400v2? Look for "Model" on the product label.
Firmware version?> [...] When I look at the Netgear Router page, under Readyshare, the
> Readycloud button does not appear (see photo). [...]I don't trust Netgear router firmware with my stored data, so I don't
use this stuff, so I don't pay close attention, but I got the impression
from my readings here that Netgear was dropping (had dropped?)
ReadyCLOUD support from recent firmware versions on some (all?) its
routers. This could be an artifact of my usual false-memory syndrome,
but, if you loaded an older firmware version and the feature reappeared,
then that would be suggestive. I'm too lazy to scan all the firmware
release notes to see if anything relevant could be found that way.
> [...] By convention NAS usually means Ethernet. That's not USB.
Sigh. "By convention", in this context, NAS means Network-Attached
Storage.https://en.wikipedia.org/wiki/Network-attached_storage
A purpose-built NAS server typically uses a high-speed interface
(Fibre Channel, SCSI, SAS, SATA, ...) to communicate with its storage
devices (disks, et al.), and an Ethernet or other network interface to
communicate with its client devices.Some router models offer some NAS capability using a USB interface to
a storage device, and the usual Ethernet interface for communication
with a client. That is what's being discussed here.Some of the participants in these forums seem to believe (and enjoy
telling others) that "NAS" means a box whose label says "NAS", rather
than a gizmo which attaches a storage device to a network.
Others believe that any gizmo which attaches a storage device, even a
USB-connected storage device, to a network, like, say, a Netgear
R6400[vX], constitutes network-attached storage (NAS). I have no
trouble with this functional definition (because I can read), but some
people seem to, which leads to "help" like:> [...] By convention NAS usually means Ethernet. That's not USB.
A USB-connected disk, by itself, is not (normally) NAS. A
USB-connected disk, when connected to a computer with the right
programming (and a network interface), can be, literally, exactly,
network-attached storage.But I don't expect to persuade the local "experts".
It's true that a purpose-built NAS server which does not use USB as
its storage interface will typically have faster hardware, and
software/firmware which is more reliable and has more features (like
RAID, for example) than a consumer-grade Netgear router-as-NAS. But,
network-attached storage is still network-attached storage. For some of
us, at least.- Mph3842Jun 01, 2021Aspirant
Thank you for your response. I agree with you that a USB attached drive is NOT the same as an NAS drive. All I want to do is to be able to upload my photos from my phone to the USB drive since Gogle Photos is now limiting space. If you can suggest a way for me to do that I would be appreciative. The upload need not be automatic as I do not mind uploading them once a week by myself but what I do want to do it to be able to uload them (or view them) from anywhere. Thanks in advance.
M
