222Graham222
Jan 30, 2024Guide
I have been having crazy problems with Readyshare
I have been having crazy problems with Readyshare, I have changed the WINS and added the unsafe SMB1 leaving my system looking unsafe.
I have found that when I open the credential manager from Cont...
- Feb 15, 2024
If you open the Credentials manager you can show the windows credentials then make the password change required, you'll see READYSHARE as a generic credential, change the password within that and voila you'll be able to use your Readyshare drives, works for both the USB cable attachments correctly.
So that is the solution to the problem caused by not being able to access your drives.It's nothing to do with adding old broken network solutions like SMB 1.0 or WINS, as long as your network is set correctly it should operate succesfully.
For some reason Windows reset that credential, for a reason I cannot understand (you'd have to talk to the programmer of that routine, good luck with that lol).
So I appear to have found a complete solution to that problem... hoorah for me!
michaelkenward
Feb 07, 2024Guru - Experienced User
222Graham222 wrote:
Open Control Panel in Windows 11; hit windows key and r type "Control Panel" and it will open the only control panel in windows change your view to your choice and open Credentials Manager, from that chose windows credentials and you can make the necessary changes using that.
What are those necessary changes?
222Graham222
Feb 15, 2024Guide
- michaelkenwardFeb 15, 2024Guru - Experienced User
Oh no. Not another place to have to mess around!
I see where you mean.
It would be interesting to see if other people can use that route rather than messing with SMB. Maybe I'll grit my teeth and see if it works here.
