simard
Feb 01, 2023Aspirant
I need a router that shows data usage per connected device
I am in need of a router that logs each device IP connected and the data used per connection per device. I need to see how much bandwidth each device is using each hour and each day. I only need stand...
Feb 01, 2023Guru - Experienced User
What N750 do you have?
Some have 3rd party options (ddwrt/tomato) that offer data tracking.
but it voids your warranty and can put you at a risk for bricking your device.
Just an option to try before buying something
- simardFeb 01, 2023AspirantWhat router can do it ? Model ?- plemansFeb 01, 2023Guru - Experienced UserYou won't find a stock netgear consumer model that will. Again, what n750 model do you have? - simardFeb 01, 2023AspirantI don't know what model N750 I have. I tried the wwrt and that doesn't work for me. I don't want to mess around with alternative firmware I just want to buy something off the shelf that I can plug in and configure and be done with it.
 If you know of a router that can do this feature please let me know the manufacturer and model number even if it's older and I will try to find it
 Thank you for your help
