simard
Feb 01, 2023Aspirant
I need a router that shows data usage per connected device
I am in need of a router that logs each device IP connected and the data used per connection per device. I need to see how much bandwidth each device is using each hour and each day. I only need stand...
simard
What router can do it ? Model ?
Feb 01, 2023Guru - Experienced User
You won't find a stock netgear consumer model that will.
Again, what n750 model do you have?
- simardFeb 01, 2023AspirantI don't know what model N750 I have. I tried the wwrt and that doesn't work for me. I don't want to mess around with alternative firmware I just want to buy something off the shelf that I can plug in and configure and be done with it.
 If you know of a router that can do this feature please let me know the manufacturer and model number even if it's older and I will try to find it
 Thank you for your help- michaelkenwardFeb 01, 2023Guru - Experienced User
 simard wrote:
 I don't know what model N750 I have.There's a label on the bottom. Netgear stopped making N750 routers about a decade ago
 If you know of a router that can do this feature please let me know the manufacturer and model number even if it's older and I will try to find itAs already explained, Netgear doesn't make these devices, so this is not something you are likely to find on a Netgear site. There aren't that many makes of consumer grade routers, to it shouldn't take you too long to track them down and visit their sites. - simardFeb 01, 2023AspirantWhy are you asking for the model when no Netgear router has this feature ? I need something that can do this without putting in an experimental firmware. I will message Cisco and see if they have something that will work.
