Lillycat12
Apr 14, 2022Follower
I need my Wi -Fi password
michaelkenward
Apr 15, 2022Guru - Experienced User
If you mean the default one on the unnamed Netgear device, look at the label on the back/bottom of the thing.
Or login to the device's graphical user interface (GUI) and look there. It is on the Home page.
If you mean some other password, then no one here can help. Ask whoever set the password.
If you have forgotten it, you will have to reset the device and set up a new password.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
If you hardwire (skips needing the wifi password to connect) into the modem/router combo device and know the gui password (default login is admin), then you could view/change the ssid.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
