baps866's avatar
baps866
I need the newest firmware for my router
Hi! I am having problems with my router running slow and was told that I needed to update the firmware for it. Can anyone please help me with locating the correct firmware to download. I truly appreciate the help. My model number is WNDR3400.
Thanks!
  • Firmware for the WNDR3400V3 is available here.  If you have a WNDR3400V2 or WNDR3400V1, then select the appropriate version on the web page.
    • FRAN52's avatar
      FRAN52
      Still waiting for firmware fix.  (netshare - print backdoor fix)
      Do we need to wait until the FEDS start ussuing fines?
      Still no brute force protection either   Why not ??
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        FRAN52 Do you have the same issue and router? If not, kindly start a new thread.
