Cakebabe
Apr 28, 2021Follower
I need to retrieve or reset my password and don't know how to do it
How do I retrieve or rest the password to my router?
Apr 28, 2021Guru - Experienced User
You can reset the device.
Push and hold reset for 7-15 seconds while its powerd on.
that should get you back to the defaults.
then you just need to reinstall the device
