Rub-lin
Aug 15, 2021Aspirant
I replaced my spectrum modem with netgear cm1000v2 but I am not getting the speed that I used to.
Netgear cm1000v2 I can't get the speed that I used to. It was more than 300mbps and now it's only 70 mbps max.
Aug 15, 2021Guru - Experienced User
are you hardwired into the modem with a pc/laptop?
how are you testing?
Do you have a screen snip of the cable connections page and the logs?
- Rub-linAug 15, 2021AspirantI’m using speedtest on my iPhone
- plemansAug 15, 2021Guru - Experienced User
That doesn't tell you how the modem is performing as its using the wireless of the router (which could be the issue).
Hardwire a pc/laptop into the modem, reboot the modem, and then test the speed on it.
That'll tell us the speed you're getting from the modem.
