SAMIBELLA
Jan 17, 2023Follower
I TURNED ON MY ROUTER TODAY TO HOOK UP AND LIGHT COMES ON GREEN AND TURNS AMBER ? RBR50
TURNED ON ROUTER TO SET UP LIGHT TURNS GREEN AND THEN AMBER I CANT RESET IT NOTHING WORKS? ITS A RBR50 A YEAR OLD I HAD IT SET UO USED FOR A WEEK WORKED FINE..
Jan 17, 2023Guru - Experienced User
1. Caps lock. Please un-click it
2. what led are we talking about? The power one?
3. did you try a factory reset? Push and hold reset for 7-15 seconds while its powered on?
4.You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
