ebisbing
Sep 24, 2015Aspirant
I want to set up the router without connecting to my mac
How can I do this?
- Sep 27, 2015
ebisbing Initial setup and best way to configure the router is to have an ethernet connection between the router and computer then router connects to the modem.
Once the router has been configured correctly, you can then disconnect the ethernet cable from the computer and use that computer to connect wirelessly.
You will just have to make sure that the router is configured and connected correctly to the modem.
The proper setup to make things work is to have the modem connected specifically to the WAN/Internet port on the router.
ebisbing
Sep 25, 2015Aspirant
I probably didn't explain what I wanted very clearly. Wording is difficult. I have an old mac mini on my desk top which is where the modem and router are . The router is connected via ethernet cord to the mac mini. If you unplug that ethernet cord - there is no wifi. I think this mac mini will die soon or need to be replaced. I would rather not do that. I have a laptop. But, if I take the laptop away and this ethernet cord is not connected to a computer - the way it is - I don't think we will have wifi.
When you follow the set up instructions they say there is a way not to have it connected to the pc/mac. How can I do that so I don't have to have a desk top computer any more? Is there a way?
ElaineM
Sep 27, 2015NETGEAR Employee Retired
