ToddeSwe
Aug 03, 2015Guide
Icy Box IB-RD3620SU3 does not work with WNDR-3700 v2?!
Hi Have attached my new Icy Box today but my WNDR-3700 v2 does not recignize it. Why is that? I have one WD 4 TB Red series NAS drive inside. Nothing happens, i have restarted it, the compute...
- Aug 06, 2015
Hi
I got an answer from the manufactor of Icy Box and they told me that it can't be connected to anything else than a PC or Mac since it needs some drivers or software to operate.
Thanks for you reply though
Torbjörn
ElaineM
Aug 06, 2015NETGEAR Employee Retired
Hi ToddeSwe,
Welcome to the community!
You may want to try using a different HDD or a thumb drive to be connected to the WNDR3700v2. What's the firmware installed on your router? Do you get a led light on when you connect your Icy Box to the router? Check also this known compatibility list.
- ToddeSweAug 06, 2015Guide
Hi
Torbjörn
