faustind's avatar
faustind
If Not Keeping Up With Firmware Updates, Will Installing Latest Update Install All Prior Updates?
I am currently using a Netgear WNR2000v3 Wireless Router. I have never installed any Firmware/Software updates. If I install the latest Firmware/Software update
(Firmware Version 1.1.2.10 ), will this include all prior updates or do I need to go all the way back and install Firmware/Software updates in the order in which they were formulated?
    • faustind's avatar
      faustind
      Thank you so much for the prompt and informative reply.
    • VE6CGX's avatar
      VE6CGX
      Master
      Rarely you have to update version by version. In this case update utility will tell when
      trying to update to latest version.
