ManuelTorres's avatar
ManuelTorres
Follower
Jul 28, 2021
IGMP snooping
Hi,
Does the IGMP Snooping functiolanity on this switch work by default or does it need to be activated?
Thank you,
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Manuals are always a good place to start. Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
    You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so there may be useful responses here, but switches don't have much in common with routers so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Smart / Plus / Click Switches - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
