spartan26
Aug 16, 2017Aspirant
Image will not upgrade
I have a WNDR3700v2 router. It is currently on firmware V1.0.0.32. I am trying to upgrade to the latest which I have downloaded (WNDR3700v2_WNDR37VVv2-V1.0.1.14.img). I keep getting the following ...
- Aug 17, 2017
> There is no firmware 1.0.0.32.
I'm sure that you must be right, but:
https://kb.netgear.com/22083/WNDR3700v2-WNDR37AVv2-Firmware-Version-1-0-0-32
Boy, that Google thing is a miracle.
Perhaps there's a reason that 1.0.0.32 is no longer available.
I know nothing, but you might try to get an answer from Netgear,
although that may be difficult and/or expensive. Failing that, there's
a TFTP scheme which may be able to force firmware of your choice down
its throat, but there is some risk of inappropriate firmware disabling
the gizmo.
michaelkenward
Aug 17, 2017Guru - Experienced User
spartan26 wrote:I have a WNDR3700v2 router. It is currently on firmware V1.0.0.32.
There is no V1.0.0.32 firmware for the WNDR3700v2.
Maybe it is a different flavour of WNDR3700. You should find the model number on a label on the back.
spartan26
Aug 17, 2017Aspirant
I have double checked and it’s firmware is 1.0.0.32 and the model number is WNDR3700V2
- michaelkenwardAug 17, 2017Guru - Experienced User
This is the support section for that device:
>> Click here >> WNDR3700v2 | Product | Support | NETGEAR << Click here <<
Have you tried using the modem's browser interface to tell it to find the newest firmware?
The manual (see link above) explains how to do this.
- antinodeAug 17, 2017Guru
the gizmo.- spartan26Aug 24, 2017Aspirant
The resolution to solving this problem was to TFTP a new image onto the router. Nothing within the documentation solved this issue. With the new image it also resolved the disconnection issue that appears after the router was online for several hours.
