spartan26
Aug 16, 2017Aspirant
Image will not upgrade
I have a WNDR3700v2 router. It is currently on firmware V1.0.0.32. I am trying to upgrade to the latest which I have downloaded (WNDR3700v2_WNDR37VVv2-V1.0.1.14.img). I keep getting the following ...
- Aug 17, 2017
> There is no firmware 1.0.0.32.
I'm sure that you must be right, but:
https://kb.netgear.com/22083/WNDR3700v2-WNDR37AVv2-Firmware-Version-1-0-0-32
Boy, that Google thing is a miracle.
Perhaps there's a reason that 1.0.0.32 is no longer available.
I know nothing, but you might try to get an answer from Netgear,
although that may be difficult and/or expensive. Failing that, there's
a TFTP scheme which may be able to force firmware of your choice down
its throat, but there is some risk of inappropriate firmware disabling
the gizmo.
spartan26
Aug 17, 2017Aspirant
I have double checked and it’s firmware is 1.0.0.32 and the model number is WNDR3700V2
michaelkenward
Aug 17, 2017Guru - Experienced User
This is the support section for that device:
>> Click here >> WNDR3700v2 | Product | Support | NETGEAR << Click here <<
Have you tried using the modem's browser interface to tell it to find the newest firmware?
The manual (see link above) explains how to do this.
- antinodeAug 17, 2017Guru
the gizmo.- spartan26Aug 24, 2017Aspirant
The resolution to solving this problem was to TFTP a new image onto the router. Nothing within the documentation solved this issue. With the new image it also resolved the disconnection issue that appears after the router was online for several hours.
- antinodeAug 24, 2017Guru
> [...] TFTP a new image onto the router.
Thanks for the update. Glad to hear that you got it working.
There is some justification to leaving the TFTP scheme out of the
normal user documentation. Too many people with problems which it
wouldn't help would use it to get into even deeper trouble. At least
it's not an actual secret.
On the bright side, from now on you won't have to worry about usingthat nonexistent V1.0.0.32 firmware.
