spartan26's avatar
spartan26
Image will not upgrade
I have a WNDR3700v2 router.  It is currently on firmware V1.0.0.32.  I am trying to upgrade to the latest which I have downloaded (WNDR3700v2_WNDR37VVv2-V1.0.1.14.img).  I keep getting the following ...
  • antinode's avatar
    antinode
    Aug 17, 2017
    > There is no firmware 1.0.0.32.
       I'm sure that you must be right, but:
    https://kb.netgear.com/22083/WNDR3700v2-WNDR37AVv2-Firmware-Version-1-0-0-32
       Boy, that Google thing is a miracle.
       Perhaps there's a reason that 1.0.0.32 is no longer available.
       I know nothing, but you might try to get an answer from Netgear,
    although that may be difficult and/or expensive.  Failing that, there's
    a TFTP scheme which may be able to force firmware of your choice down
    its throat, but there is some risk of inappropriate firmware disabling
    the gizmo.
