dvj
Aug 20, 2022Follower
Important Security Firmware Update from NETGEAR
I have a Nighthawk MR60 Mesh network, which I bought from costco less than a year ago. I got an email which stated: Important Security Firmware Update from NETGEAR We've Enhanced Your Pro...
michaelkenward
Aug 21, 2022Guru - Experienced User
dvj wrote:
I call Netgear support and they were pushing me to buy tech support, which I didn't.
They told me that the latest firmware version is V1.1.6.124. I have version V1.1.6.122.
At http://routerlogin.net/start.htm under advanced -> router update, I only see version V1.1.6.122, and it states "No new firmware available".
Who did you call? Not, I hope, someone you found with an Internet search. That is a good way to reach scammers.
The on-board check for new firmware is unreliable. It can miss updates. It can also be a while before updates hit the automated update servers.
The best way to check is to visit the support pages for your device and to look at the library of available updates.
Support | NETGEAR
Feed in your model number and look for firmware for your device.
The release notes should also tell you how to manually update the firmware.
MR60 / MS60 Firmware Version 1.1.6.124 | Answer | NETGEAR Support
Or read this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
What should I do? Do I need to update to firmware version V1.1.6.124 ?????
Yes.
