Friedbones
Jun 23, 2017Guide
Important Security Update from NETGEAR: New Firmware Is Available for Your Product
I've been told by my isp that they push out firmware updates to their customers. Will the Netgear offering cause our isp connection to fail if the firmware does not match our isp's specs? Or is this...
- Jun 27, 2017
Hi Friedbones,
Firmware updates pushed out by your ISP is usually for the device/s (modem/modem-router) that they provide. The firmware update for your NETGEAR router should not affect your connection. We recommend proceeding with the update. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
DexterJB
Jun 27, 2017NETGEAR Moderator
Hi Friedbones,
Dexter
Community Team
Friedbones
Jul 07, 2017Guide
I have a question about the Netgear firmware update. Will this completely reset all my settings as well as my login ID and PW? Will I have to completely redo my setup?
It was such a pain to set it up when I first bought it...took me over 2 hours to do because I kept getting a "set pw" notice every time I set a password. I finally just left it with the final one I created and closed everything down....but the only way I knew things actually worked was when I closed out everything and restarted. Then I rebooted my pc and was able to get online.
The setup process for Netgear is extremely difficult and frustrating, you would think they could have made it easier for users to work with.
