pbackstrom
Jan 22, 2024Aspirant
In loop trying to log on
When I try to log on, either with a one-time password or with my password, it says “Your router is registered to [my email, the same one as I’m trying to get on with]. Login using this account an...
- Jan 23, 2024
pbackstrom wrote:
Not sure. I'm supposed to be checking to see if the router is up to date per a security article.
The best way to check the firmware on your router is with a web browser and the graphical user interface (GUI).
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
You can see the firmware version there.
To see if it is latest check the support pages:
Support | NETGEAR
That page will have a library of firmware for your device.Then there is this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
microchip8
Jan 22, 2024Master
Log on where?
Where is a one-time password used? I've never heard that for an NG router.
- pbackstromJan 22, 2024Aspirant
Hmm, can't replicate. Email is below. I did try resetting my password as well.
The main problem is I'm in Nighthawk, it shows a graph of my router plus Device Manager, Security, Internet Speed etc. I click Security and it takes me to the sign on screen that I keep looping back to. I push "Sign In," then "Sign into existing account," put my email and password in, and I'm back to the looping screen.
- microchip8Jan 22, 2024MasterSo you're in the app and try to access Security? Which, if I recall, is about Armor/Bitdefender?
- pbackstromJan 24, 2024Aspirant
I got on directly so this is resolved. Here's the OTP screen for your information. Thanks.
