pbackstrom
Jan 22, 2024Aspirant
In loop trying to log on
When I try to log on, either with a one-time password or with my password, it says “Your router is registered to [my email, the same one as I’m trying to get on with]. Login using this account an...
- Jan 23, 2024
pbackstrom wrote:
Not sure. I'm supposed to be checking to see if the router is up to date per a security article.
The best way to check the firmware on your router is with a web browser and the graphical user interface (GUI).
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
You can see the firmware version there.
To see if it is latest check the support pages:
Support | NETGEAR
That page will have a library of firmware for your device.Then there is this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
pbackstrom
Here's the screen I keep getting
Jan 22, 2024Guru - Experienced User
Have you tried a factory reset on the router, use a web browser to set up the router from scratch.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Then after it's setup, try using the NH app to log in?
- microchip8Jan 22, 2024MasterSecurity on the app is not there to see if the router is up to date. It's there for Armor
