pbackstrom
Jan 22, 2024Aspirant
In loop trying to log on
When I try to log on, either with a one-time password or with my password, it says “Your router is registered to [my email, the same one as I’m trying to get on with]. Login using this account an...
- Jan 23, 2024
pbackstrom wrote:
Not sure. I'm supposed to be checking to see if the router is up to date per a security article.
The best way to check the firmware on your router is with a web browser and the graphical user interface (GUI).
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
You can see the firmware version there.
To see if it is latest check the support pages:
Support | NETGEAR
That page will have a library of firmware for your device.Then there is this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Jan 22, 2024Guru - Experienced User
Have you tried a factory reset on the router, use a web browser to set up the router from scratch.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Then after it's setup, try using the NH app to log in?
microchip8
Jan 22, 2024Master
Security on the app is not there to see if the router is up to date. It's there for Armor
