pbackstrom
Jan 22, 2024Aspirant
In loop trying to log on
When I try to log on, either with a one-time password or with my password, it says “Your router is registered to [my email, the same one as I’m trying to get on with]. Login using this account an...
- Jan 23, 2024
pbackstrom wrote:
Not sure. I'm supposed to be checking to see if the router is up to date per a security article.
The best way to check the firmware on your router is with a web browser and the graphical user interface (GUI).
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
You can see the firmware version there.
To see if it is latest check the support pages:
Support | NETGEAR
That page will have a library of firmware for your device.Then there is this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
microchip8
Jan 22, 2024Master
Log on where?
Where is a one-time password used? I've never heard that for an NG router.
pbackstrom
Jan 24, 2024Aspirant
I got on directly so this is resolved. Here's the OTP screen for your information. Thanks.
