Michael_O's avatar
Michael_O
Follower
Jan 01, 2017
Inconsistent USB Storage Connection
I have two Macs that I want to set up with automatic Time Machine backups over WiFi. I used to do this with an Apple Time Capsule, no problem.   I have two hard drives in an IcyRAID enlcosure (MB66...
  • DexterJB's avatar
    Jan 03, 2017
    Hi Michael_O,
    I believe the issue of the changing drive names can be addressed if there is a stable connection between the router and the enclosure. Unfortunately, there is no way for you to assign a volume name to a specific drive. I would also like to confirm the following information:
    1. What is the model number and firmware version of your NETGEAR device?
    2. Is the 200 MB storage that is being detected referring to the internal flash memory ? Or is it another storage device?
    3. Have you tried resetting the router?
    4. Have you tried re-flashing the firmware?
    5. Is the enclosure connected to the USB 2.0 or 3.0? Have you tried swapping?
    6. Is the connection stable if the enclosure is connected straight to a computer?
    7. Are the drives set to JBOD configuration?
    Dexter
    Community Team
