Michael_O
Jan 01, 2017Follower
Inconsistent USB Storage Connection
I have two Macs that I want to set up with automatic Time Machine backups over WiFi. I used to do this with an Apple Time Capsule, no problem. I have two hard drives in an IcyRAID enlcosure (MB66...
- Jan 03, 2017
Hi Michael_O,
I believe the issue of the changing drive names can be addressed if there is a stable connection between the router and the enclosure. Unfortunately, there is no way for you to assign a volume name to a specific drive. I would also like to confirm the following information:
1. What is the model number and firmware version of your NETGEAR device?
2. Is the 200 MB storage that is being detected referring to the internal flash memory ? Or is it another storage device?
3. Have you tried resetting the router?
4. Have you tried re-flashing the firmware?
5. Is the enclosure connected to the USB 2.0 or 3.0? Have you tried swapping?
6. Is the connection stable if the enclosure is connected straight to a computer?
7. Are the drives set to JBOD configuration?
Dexter
Community Team
