dhda's avatar
dhda
Insight second authentication
Insight uses second authentication, primary attached to a phone, no longer being operational.
Deleting is not enabled because it's the primary method.
Changing or adding another phone seems not possible.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have a piece of unnamed Netgear hardware that uses Insight?
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    Maybe this place would be more appropriate:
    NETGEAR Insight Network Management - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
