Travelman54's avatar
Travelman54
Initiate
Nov 17, 2023
Installation of ReadySHARE Printer Utility Version 3.1 incomplete on Mac OS 14
Installing on 27 inch iMac running the latest version of Mac OS 14 NETGEAR USB Control Center is installed but as soon as I open it I get the message that the installation is incomplete with the que...
  • DaneA's avatar
    Dec 29, 2019
    jakecrew,
    If you will deploy another firewall router behind your existing router provided by your ISP, you will have a Double NAT scenario.  To know more about Double NAT, access the article below:
    What is Double NAT?
    To know the ways on how to solve issues (or prevent) Double NAT scenario, access the article below:
    How to fix issues with Double NAT?
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
