Travelman54
Nov 17, 2023Initiate
Installation of ReadySHARE Printer Utility Version 3.1 incomplete on Mac OS 14
Installing on 27 inch iMac running the latest version of Mac OS 14 NETGEAR USB Control Center is installed but as soon as I open it I get the message that the installation is incomplete with the que...
- Nov 18, 2023
Hi, just found out that I do not need the Printer Utility.
When I go to "Printers & Scanners" in my iMac System Settings and click on the button "Add Printer, Scanner or Fax..." the printer I connected to the router's USB port is available and I can install it using the standard print driver that is available for the model printer.
So I removed the incomplete "NETGEAR USB Control Center" app.Will close this thread.
Travelman54
Nov 18, 2023Initiate
michaelkenward
Nov 18, 2023Guru - Experienced User
Good feedback. Thanks.
Installing the print driver in the usual way is probably the key to it. Even Windows needs that.
If you ever try to use the printer for wifi printing, the usual trick is to get the network utility from your printer maker. (Some printer makers are better than others at that) But even there the Mac might be able to use its built-in tools for that.
