Muthanna
Mar 22, 2021Follower
Intermittent wifi issue (Model C3000)
Hi , We are facing intermittent wifi connection issue. Note : Network (Comcast) technician told that its issue with the router. need to update the router frame. Please help to take it forward. ...
Mar 23, 2021Guru - Experienced User
Only the wifi is having issues?
Wired devices work fine?
What actual issues are you having? A detailed description of whats happening/going on helps more than "intermittent wifi issue"
Also, the C3000 is a single band 2.4ghz device. 2.4ghz is more sensitive to interference and its slow. If you live in an apartment/condo/residence with a lot of signals, you will likely fact connection issues because the 2.4ghz bandwidth gets over crowded in those locations.
