casselak
Apr 29, 2021Follower
intermittent wifi
I had a general area power cut a few weeks ago and now suffer intermittent wifi drop-out. I've contacted the ISP (Sky) who say the connection to the house is good (69Mb) and steady. I have a Sky rout...
Apr 30, 2021Guru - Experienced User
Turning off wifi doesn't disble the router functions on the sky box.
It can cause a double nat.
What is Double NAT? | Answer | NETGEAR Support
Not saying thats the issue but I usually recommend fixing double nat issues first.
options? (only use 1)
1. put the sky box in passthrough/modem only mode.
2. put the netgears IP address into the sky box's DMZ
3. put the netgear in access point mode.
