NRod84's avatar
NRod84
Internet blinking amber rapidly
So I just moved and transferred over my service with same modem and router. Internet is working just fine if I plug the Ethernet directly into my laptop, but when I plug it into router the internet li...
  • antinode's avatar
    antinode
    Oct 06, 2017
    > I downloaded the latest firmware, [...]
       Ok.
    > [...] I'm using a laptop and only have one ethernet port and I need
    > that to connect directly to modem to have internet.
       After you've downloaded the firmware kit, why do you need to maintain
    Internet access?  Forget the Internet.  Connect your computer to your
    router, and do the firmware update.
    > Am I missing something? Or can I log into my router offline?
       Probably.  [www.]routerlogin.net should point to your own router, not
    to some outside-world Web site.
