airasel
Apr 19, 2018Aspirant
Internet Connection Drop & Traffic Meter Issues, after updated to latest FW.
Electricity drops several times in my house, when it back the Router has (No Internet Connection). After manually reboot the Router it connect to the Internet again. Traffic Meter Statistics values (...
- Apr 20, 2018
Thank you for your reply, I called my ISP to check the Fibre Modem and whatever it called actually they told me it's a EPON ONU.
Finally they told me The Router and the Fibre Modem both are okay, but they find a issue in Router QoS Setup / Turn Bandwidh Control On option (Cheacked) and selected with Automatically check Internet Uplink Bandwidh, after disabled Bandwidh Control option Connection Drop fully disappear.
michaelkenward
Apr 20, 2018Guru - Experienced User
Have you set the Connection Mode to always on? See page 23 in the manual:
>>> R6220 | Product | Support | NETGEAR <<<
But without knowing what this fiber modem is, that is just a guess. Maybe that is where the problem lies.
airasel
Apr 20, 2018Aspirant
