mtarallo
Mar 08, 2019Aspirant
Internet disconnects randomly only when wired to WNDR4500v2
Hi there - thanks for taking a look. (This post is all about wired networks.)
I have been working flawlessly for over 3 years with my charter spectrum Arris router and Netgear WNDR4500v2 as an ...
- May 03, 2019
OK it is confirmed and what was suspect - IDC but connectors splice in junction box was covered in a greasy gel like substance, possibly causing the issue. The IDC connectors were leaking there gel after X amount of years.
Problem solved!
mtarallo
Mar 09, 2019Aspirant
UPDATE:
I tested the cable run from my detached office to the mail panel with this:
https://www.amazon.com/gp/product/B06XZYXN63/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The cable seems fine, all green lights blinking in sequence.
I switched out WNDR4500v2 with a WNDR4500v3 and configured it as an AP. I assigned static IPs. Changed my main router / cable modedm to use 192.168.2.1 - Hooked everything back up - I first plugged the WAN port from the WNDR4500v3 to the wall - I was getting about 80Mbps which is what I would nomally get. I left it alone. it has been running without issue for a few hours. I cam back and ran a speed test and now only get 8Mbps. I see many ports that state not to use the WAN port - but not sure why the picture on the AP page shows you that you should use the WAN port. Anyway - I switched the cable from the wall to another ethernet port and ran speed test and got 80Mbps again. I have no clue WTH is going on here. Things that worked without issue for many years you would think would continue to. All I did was move in and hook up a wired machine to the existing router and that when all this hell started. At the moment I am still connected and getting 80Mbps. So we will see what happens. I'll post an update tonight.
mtarallo
Mar 11, 2019Aspirant
UPDATE # - or hell I lost count - 3 or 4 I think. :smileyhappy:
OK so yesterday (Sunday) everything was running smoothly (it ran all trough Saturday night without isse) until about 12:30PM on Sunday. That is when I lost conenctivity (I can tell because I have NEST outdoor cams that disconnected in that area) BUT it reestablished around 1:30pm and I have it all day today - woth some noticeable hiccups but not a complete outage.
Keep in mind when this happens, the whole house DOES NOT lose connectivity - just my detached office. Today spectrum came and tested the COAX lines coming into my home and to the modem and all was green. While he was there he witnessed the port activity (blinking lights on the port) on the technicolor modem- where the wire was coming from my deattched offce (the netgear AP) - he saw the light turn from green (1GBps) to amber (100Mbps) - he watched it flip back to green - so we just through our hands up and are concluding that there has to be a bad cat5e wire somewhere between the main home and my deattached office - perhaps damaged in the remodel.
However, what is weird is that internet connectivity it works for long periods of time - I would assume if it was a bad cable - would it NOT work consistently?
ANYWAY!!!
Before the spectrum tech was ready to leave, I recall seeing (through dozens of internet searches) that technicolor modems and netgear routers "don't play nice with each other" - not really knowing what that means - as a last ditch effort - i asked the tech if he had an Arris modem. He did and we hooked it up. At this time I am in my office and getting super speeds and consistency writing this post.
Is it possible that lone internet forum poster was right? Perhaps originally when this whole thing started, I had a bad wire in my drop (which originally lead me to think my modem was bad, andwhy I swapped it out and then actually made things worse? Causing a "red herring" situation? Only time will tell.
Here is my current speed test:
I will update you all again if all seems to last.
- mtaralloMar 11, 2019Aspirant
OK - continuing this troubleshooting - back online after another bout of internet disconnect - being anxious and assuming all seemed to be working - I went an attempted to configure my LED light strips: I got from Amazon here - (now this happened to me earlier but I did not think anything of it) - as I configured the WiFi LED strip using my phone - and it attemtped to connect - my amazon echo comes on and states - "i lost connection to the internet" - is it coincidence that this happened - at exactly the same time? So I just packed them up and sent them back - but now thinking I infected my network some how - who knows with this stuff - I factory reset my modem - and all is back on line. At the same time I unhooked my netgear AP and plugged it directly into my pc and all is working again. WTH is going on? I'll report back.
