mtarallo
Mar 08, 2019Aspirant
Internet disconnects randomly only when wired to WNDR4500v2
Hi there - thanks for taking a look. (This post is all about wired networks.)
I have been working flawlessly for over 3 years with my charter spectrum Arris router and Netgear WNDR4500v2 as an ...
- May 03, 2019
OK it is confirmed and what was suspect - IDC but connectors splice in junction box was covered in a greasy gel like substance, possibly causing the issue. The IDC connectors were leaking there gel after X amount of years.
Problem solved!
mtarallo
Mar 09, 2019Aspirant
UPDATE:
I tested the cable run from my detached office to the mail panel with this:
https://www.amazon.com/gp/product/B06XZYXN63/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The cable seems fine, all green lights blinking in sequence.
I switched out WNDR4500v2 with a WNDR4500v3 and configured it as an AP. I assigned static IPs. Changed my main router / cable modedm to use 192.168.2.1 - Hooked everything back up - I first plugged the WAN port from the WNDR4500v3 to the wall - I was getting about 80Mbps which is what I would nomally get. I left it alone. it has been running without issue for a few hours. I cam back and ran a speed test and now only get 8Mbps. I see many ports that state not to use the WAN port - but not sure why the picture on the AP page shows you that you should use the WAN port. Anyway - I switched the cable from the wall to another ethernet port and ran speed test and got 80Mbps again. I have no clue WTH is going on here. Things that worked without issue for many years you would think would continue to. All I did was move in and hook up a wired machine to the existing router and that when all this hell started. At the moment I am still connected and getting 80Mbps. So we will see what happens. I'll post an update tonight.
DexterJB
Mar 11, 2019NETGEAR Moderator
Hi mtarallo,
Welcome to the community!
Looks like you've done quite a few steps already.
1. Did you get to keep the Arris modem or did you have the Technicolor setup back?
2. Do you still have the WNDR4500v3 setup in the office? To confirm, it is behaving exactly the same as the WNDR4500v2, correct?
3. When you swapped the WNDR4500v2 with the WNDR4500v3, was the WNDR4500v2 behaving normally without issues where you relocated it?
4. Does the issue persist if you have any of the routers (either the v2 or v3) configured in router mode (for isolation)?
Dexter
Community Team
- mtaralloMar 11, 2019Aspirant
Hi Dexter - thanks for the reply:
Yes - I am back to using the Arris modem
correct - I do have it available, but as a test I switched over to a D-Link AP for giggles just to see. I can return to Amazon if the issues persists.
Yes - my v2 and v3 in the house are working as they have been for the past 3 years. Only difference now - they are purely wireless APs with no wired devices.
That is a good question - my network knowledge is still limited, I am a creature of habit. I always used AP mode as I was told that the main modem router should be doing the router capabilites. I was about to switch to Bridged mode on my mome and have netgear perform the routing capabilites but the cable provider wanted to come out and test all the lines first. So we still have some options here. I also don't know enough about line integrity - I don't have a FLUKE or anything - just the simple cat 5 line tested which proved to be fine. So I'm being a bit stubborn about it being a bad wire - as my computer when directly connected works fine - but you don't know what you don't know right? :-)
So one more quick update before bed - I just setup a DLINK DAP-1650 Wireless AC1200 in AP mode - after completely factory resetting my Arris modem, after the LED WiFi incident mentioned above.
I'm back online at the moment and my WiFi is working and my connected / wired PC is working.So here is what is left in this big mess of things:
- a possible intermittent cat5e issue in the line from my office to the main panel (though all is working at the moment)
- possible issue with Netgear router in AP mode
- possible network corruption from LED WiFi lights I got on Amazon - I know it sounds weird but that is when I observed the issue.
- Maybe there were too many devices on the 2.4GHz WiFi?
Is that possible that could cause an issue and adding the LED modules made it crash?
I have 5 Wifi Bulbs - that is 5 IPs
there were 12 LED bulbs - 6 chained together on 2 Wifi Modules - 2 more IPs
1 Wifi thermostat RF module to control a mini-split - 1 IP
1 computer with a USB Wifi adapter - 1 IP
1 amazon echo - 1 IP
1 HP Wireless printer - 1 IP
1 NEST Outdoor camera -1 IP
for a total of 12 on the SSID - does not seem like a lot.
I will report back tomorrow morning.
