ClevelandBaller
May 30, 2017Aspirant
Internet Down After Changing DNS?
I have an N750 router and am using it in an Air Force dorm, so all I normally need to do is plug it into the wall and it works. This is how I used it for the last 7 months, until I tried to change the...
- Jun 03, 2017
Try cloning your laptop's MAC address onto the router. The option is on the router's Internet Setup screen towards the bottom.
ClevelandBaller
May 31, 2017Aspirant
The model number is WNDR4300V2. All of the lights are lit as they normally are
ElaineM
Jun 01, 2017NETGEAR Employee Retired
Try to do another factory reset then reconfigure the router.
I suggest that you use a paper clip in resetting the router.
