ClevelandBaller
May 30, 2017Aspirant
Internet Down After Changing DNS?
I have an N750 router and am using it in an Air Force dorm, so all I normally need to do is plug it into the wall and it works. This is how I used it for the last 7 months, until I tried to change the...
- Jun 03, 2017
Try cloning your laptop's MAC address onto the router. The option is on the router's Internet Setup screen towards the bottom.
ClevelandBaller
Jun 01, 2017Aspirant
Tried that a couple days ago and didn't seem to work
- ElaineMJun 01, 2017NETGEAR Employee Retired
If you connect a PC straight to the wall, will you have internet access?
If you do, try to follow the steps below.
