ClevelandBaller
May 30, 2017Aspirant
Internet Down After Changing DNS?
I have an N750 router and am using it in an Air Force dorm, so all I normally need to do is plug it into the wall and it works. This is how I used it for the last 7 months, until I tried to change the...
- Jun 03, 2017
Try cloning your laptop's MAC address onto the router. The option is on the router's Internet Setup screen towards the bottom.
ClevelandBaller
Jun 01, 2017Aspirant
Still didn't work :/ I've actually basically been using my laptop as a router with no problems by connecting with an Ethernet cable directly to the wall and just setting up a hot spot if that provides any clues
ElaineM
Jun 02, 2017NETGEAR Employee Retired
Can you clarify further on what you meant by "using my laptop as a router...?"
How are things connected to the router?
Normally, the router is in the center of all devices. The router will be the one to provide internet access on wired and wireless devices you have.
So from the wall, the cable should be connected to the Internet or WAN port on the router and for configuration purposes you will have a PC to be connected to one of the 4 LAN ports.
I cannot access the Internet with my NETGEAR router; what troubleshooting steps should I follow?
