ClevelandBaller
May 30, 2017Aspirant
Internet Down After Changing DNS?
I have an N750 router and am using it in an Air Force dorm, so all I normally need to do is plug it into the wall and it works. This is how I used it for the last 7 months, until I tried to change the...
- Jun 03, 2017
Try cloning your laptop's MAC address onto the router. The option is on the router's Internet Setup screen towards the bottom.
ClevelandBaller
Jun 03, 2017Aspirant
I currently have my laptop connected directly to the wall, and I set up a wifi hotspot from my laptop to connect my phone to, which is what I meant when I said I was using it as a router. This works fine, but i means I can't carry my laptop around because then I would have to unplug it. The router isn't plugged into anything right now.
- TheEtherJun 03, 2017Guru
