PeterH1976
Jan 27, 2016Aspirant
Internet LED amber and some devices work - others do not
Hi, I am trying to find a solution for a “Windows can't communicate with the device or resource (Primary DNS Server)" error. This somehow seems to be related to the Internet LED on my Netgear rout...
- Feb 07, 2016
Sorry for the delay but....
I found the problem after many attempts, taking the router to a friend's house and trying it there etc.
The unit was faulty! Now with a new router everything is back to normal and I am very grateful for your help and patience.
Peter
Retired_Member
Jan 27, 2016push reset on router and power cycle modem
If you reply you might include the make and model of the modem and model # of the router
- PeterH1976Jan 27, 2016Aspirant
Hi,
Thank you for the response. I was at work when i wrote the post.
The router is a R6300 and the modem is the VirginMedia Super Hub which is also a Netgear product.
I tried the reset button and power cycling the modem but without any luck.
Thank you and all the best,
Peter
- DexterJBJan 27, 2016NETGEAR Moderator
Hi @PeterH1976,
1. Is the VirginMedia Super Hub a modem-router combo?
2. If yes, is it also broadcasting it's own wireless signal?
3. Are the laptops connected to the Wi-Fi of the R6300 or the VirginMedia Super Hub?
Dexter
Community Team
- PeterH1976Feb 07, 2016Aspirant
Peter
