RjhasQuestions
Aug 28, 2016Aspirant
Internet LED blinking AMBER
Hello. Here's my setup. TWC Internet service, Netgear CM400 modem, and Netgear AC1750-R6400. Service and products are only 2 weeks old and fireware is updated to most recent. Everything went smooth...
- Jun 19, 2017
Hi jgold218,
1. What is the model number of your device?
2. Please make sure that your computer is able to go online when connected straight to the Comcast modem.
3. The amber Internet light indicates that there is no Internet access.
4. If you computer is able to go online when connected to the modem, you can try MAC spoofing. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
RjhasQuestions
Sep 07, 2016Aspirant
I reset the router using the reset button on the back of the router but the internet light is still blinking AMBER.
Retired_Member
Sep 08, 2016try a different cable blinking orange may mean the connection is 10~100 not 1000m
Login to router status to view the connections
