RjhasQuestions
Aug 28, 2016Aspirant
Internet LED blinking AMBER
Hello. Here's my setup. TWC Internet service, Netgear CM400 modem, and Netgear AC1750-R6400. Service and products are only 2 weeks old and fireware is updated to most recent. Everything went smooth...
- Jun 19, 2017
Hi jgold218,
1. What is the model number of your device?
2. Please make sure that your computer is able to go online when connected straight to the Comcast modem.
3. The amber Internet light indicates that there is no Internet access.
4. If you computer is able to go online when connected to the modem, you can try MAC spoofing. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
jgold218
Jun 16, 2017Aspirant
I am having a similar issue. I have power cycled both the modem and router numerous times, called Comcast numerous times and determined it was not a Comcast issue. I have changed the Ethernet cable each time and still no connection to wifi.
Does the amber blinking light mean there is no wifi connection?
DexterJB
Jun 19, 2017NETGEAR Moderator
Hi jgold218,
Dexter
Community Team
