bhandari88
Jul 14, 2020Aspirant
Internet LED not lit- No internet C6250
Hello, My friend had internet connection till yesterday with a router (modem+router combo). Today, I got a new Spectrum account in my name with the same router that I bought from my friend. Now, ...
- Jul 14, 2020
Thank you for the reply and suggestion. My problem was actually "Network Access denided by MSO" which is explained in this post.
Thank you for the solution in this post. In addition to the solution to the post, the reason for showing up that message in router login dashboard was incomplete cancellation of the MAC address from the previous account (of my friend). I called the Spectrum and fixed the issue.
Jul 14, 2020Guru - Experienced User
Did spectrum ever activate the C6250?
Can they ping it?
you might want to post in the cable modem/router section if you have the C6250
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
bhandari88
